Dear All,
How can I copy created filters from one file to another file ?
Kindly let me know as soon as possible if anybody has a solution of my question.
Aniket Manjrekar
Open the project that you wish to transfer them to. Go to Manage Tab » Transfer Project Settings and a dialog box will appear. Choose from which project to copy the filters from, and then ensure that the Filters checkbox is checked, along with anything else you would like to transfer.
Thank u so much for ur reply.
I have tried it but by using that tool we can only transfer the projects standards like annotations, sizes, types, settings, etc.
I want to transfer filters, worksets, familys and all those thing which i have inserted in that perticular file.
Aniket Manjrekar
You should be able to use that tool to transfer filters as well. It works even in RMEP2010. The filters that you transfer must be added to the view in which you want to apply them - they do not automatically apply themselves to views. You can also transfer View Templates and then assign them to views. Below is an image of the dialog box I am referring to...
Hello, and welcome to the Discussion Groups!
I've tested this and have successfully transferred View Filters from one Project to another. Can you elaborate on your situation a little bit?
- What version of Revit are you using?
- Can you replicate this failure? Create two new Projects, create a View Filter in one, and transfer it to the other.
- Are you attempting to use Transfer Project Standards from another open Project or a Linked Model?
- Are you encountering problems with other categories using Transfer Project Standards?
When you tested the filter transfer procedure were you performing the test on a filter that may not have valid criteria in context of the target file? My guess is that if the filter transfer does work in some cases but not for the original poster's case then there is something in the filter that is not transferable to the target file. Filter criteria is not necessarily universal for every file. Filters using workset names in the criteria fall into this category. If that is what is happening and if workset names can also be transfered then perhaps the solution is to also include the missing workset in the transfer if they can also be transfered.
Actually, that is exactly the test I performed - I transferred from Workset-dependent View Filter from a Workshared Project into a non-Workshared Project, and the transfer was successful. When I opened the View Filter to investigate, the filter rules lost their association with Worksets. If a View Filter's Rules are dependent on a Project Parameter, then that Project Parameter will automatically be transferred to the current Project.
A possible alternative to using Transfer Project Standards is that you can cut and paste anything if you know its ID. So use Revit Lookup to check the ID of the filters you want to copy, use Select by ID(s) to select them, then cut and paste to other project. This is very handy when you want just a single View Template or something. It may still not work properly if its dependent on other things which dont exist in the new model, but its possibly a way around that error message.
