Revit MEP
Revit MEP
Active Member
septembersmile
Message 1 of 3 (204 Views)
filter & control the Archi Revit Reference catagoies
204 Views, 2 Replies
11-25-2012 09:13 PM
Hi. Everyboday .. Good day to u :smileyhappy:
Please help me to give advice how to filter & control the Archi Revit Reference catagoies ..(for example .. I want to be off the Demolish Categories .)
Many Thanks ,
Smile
In order to control the appearance and visibility of the Categories belonging to a linked model separate from your model's settings, go to Visibility/Graphics Overrides » Revit Links. Under Display Settings for the link(s), click on the button which will read either "By Host View" or "Custom". This will take you to another dialog titled "RVT Link Display Settings" which appears just like V/G. In the first tab, set the top option to "Custom" and then you can go to the other tabs (set the pull-down at the top to read "Custom") and set the visibility as desired.
CADastrophe
Message 2 of 3 (190 Views)
Re: filter & control the Archi Revit Reference catagoies
11-26-2012 05:16 AM in reply to: septembersmile
Active Member
septembersmile
Message 3 of 3 (186 Views)
11-26-2012 06:29 AM in reply to: CADastrophe
Thank You Very Much for your Reply ::smileyhappy:
