Solved by revitworkbench. Go to Solution.
I've received your family file via email. The Connectors appeared to function correctly when I loaded it into a Project. I noticed that this Family is designed to be used in conjunction with a Type Catalog - perhaps the problems lies within that file.
You can find some info in WikiHelp and by searching this forum. Aside from that, I'm not sure. Attached is a simple example .rfa Family file (Revit 2012) and a Type Catalog file it if helps.
Ok, so I think I pretty much knew what a type catalog was I just never new it had a name. But, the problem I have with them is stated clearly in Wiki help: "You place this file in the same location as the family file so that when you select to load the family, the type catalog displays." regardless of where I saved it I could never get it to open properly. The problem was that I opened the family first, then tried to load it into the project. By doing so, no catalog popped up telling me which types to select. The part I was missing is you have to load it directly from the project you want it in, then the type catalog will show up.
