Revit MEP
Active Contributor
rschnureIV
Message 1 of 22 (989 Views)
Fatal error loading family
989 Views, 21 Replies
07-18-2012 08:10 AM
I am getting fatal errors when I try to load certain families into my revit mep 2012 projects.  Any Ideas?
CADastrophe
Message 2 of 22 (987 Views)
Re: Fatal error loading family
07-18-2012 08:12 AM in reply to: rschnureIV
Can you provide a little more info - perhaps an image of the error message?
Active Contributor
rschnureIV
Message 3 of 22 (985 Views)
07-18-2012 08:18 AM in reply to: CADastrophe
I attached a pic of the error.  Trane seems to think it has something to do with shared parameter files?  Does this sound familiar?
CADastrophe
Message 4 of 22 (980 Views)
07-18-2012 08:33 AM in reply to: rschnureIV
I was hoping there'd be some actual, useful information in that message...
Well, in order to determine if it is in fact a problem with Shared Parameters, you can perform this test:
Open the family, and remove ALL parameters that you can, and then load it into a blank project. Does it still crash?
If not, can you post the family file so we can take a gander?
Active Contributor
rschnureIV
Message 5 of 22 (976 Views)
07-18-2012 08:44 AM in reply to: CADastrophe
I can load this family into a blank project with no errors
CADastrophe
Message 6 of 22 (969 Views)
07-18-2012 09:03 AM in reply to: rschnureIV
Now try loading it into the project that crashed.
Active Contributor
rschnureIV
Message 7 of 22 (966 Views)
07-18-2012 09:06 AM in reply to: CADastrophe
There is no attachment
CADastrophe
Message 8 of 22 (964 Views)
07-18-2012 09:14 AM in reply to: rschnureIV
Sorry, I meant loading yours with the removed parameters. It if doesn't crash, then the troublesome parameter can be isolated.
Active Contributor
rschnureIV
Message 9 of 22 (961 Views)
07-18-2012 09:20 AM in reply to: CADastrophe
I removed all the parameters I could and it still crahsed when I inserted it.
Product Support
Chris.Aquino
Message 10 of 22 (928 Views)
07-23-2012 08:26 AM in reply to: rschnureIV
After a search of our Customer Error Report database, I don't see any from your email address. Can you please post a journal from a session where you saw the crash?
They should be in the location below:
C:\Users\%username%\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2012\Journals
Chris Aquino
Knowledge Domain Expert
Customer Service & Support
The Revit Clinic
@Revitclinic
