Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Family Types
2 REPLIES 2
Jrooker06
572 Views, 2 Replies
Family Types
I have created a new family that i need the text to be editable. in the revit family that i attached i am trying to be able to bring the family into the project and under the different types have it automatically say what i named the type. in this family i have a type called TxM and FB#, I am trying to make it where they show the TxM and FB# but both of the family say TxM when i place it in the model. Is there any way to have it do what i want it to do? if so where am i going wrong?
2 REPLIES 2
L.Maas
in reply to: Jrooker06
If you want to make sure that you have the right value for the right type. Then use a type parameter. In your case you have used an instance parameter. This can already be seen from the (default) after the parameter name. So change this to a type parameter.
Instance parameters can be changed for every instacne of that particular component.
Louis
Please mention Revit version, especially when uploading Revit files.
Jrooker06
in reply to: L.Maas
Thank You
