Solved by CoreyDaun. Go to Solution.
The warnings may not be related to the newly-created parameter (I'm assuming it's a URL Type parameter, and that can be blank). In your Family, is there a Parameter that is driving Model Text, by chance? If so, check through the Types and see if there is a blank entry causing this error.
Yes, and yes! I dont know how you knew to check that, but that was pretty amazing!
