Revit MEP
Valued Contributor
lsop1409
Message 1 of 3 (266 Views)
Accepted Solution
Family Material/Render
266 Views, 2 Replies
03-05-2014 05:40 AM
I am trying to apply materials to the sockets I have created in the attached picture, but the materials are not showing up. The dado trunking is from a manufacturer and shows 'white plastic' fine and I can change materials on this fine.
I have added a parameter to the sockets called 'finish' of type 'materials' and can select the materials ok when I 'edit type' of the socket family, but the materials will not show in realistic view.
Within the Family Editor, you have to assign the Material to the Extrusion(s). Select one or more Extrusions and under Properties, you will find a parameter for Material. Click on the gray button to the right side of that and link it to the Materials Parameter that you created. You could also import that Material into your Family and directly assign this Material instead of linking to a Parameter. An easy way to import the Material is to Copy/Paste an element of that Material from another Family file.
*Expert Elite*
CADastrophe
Message 2 of 3 (241 Views)
Re: Family Material/Render
03-05-2014 08:55 AM in reply to: lsop1409
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Valued Contributor
lsop1409
Message 3 of 3 (199 Views)
03-10-2014 05:15 AM in reply to: CADastrophe
Thankyou
I have copied and pasted a family from a manufacturer containing preset materials and assigned some of those.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
