Hi
How can i change the color of a family?? i am using Revit mep 2012 and some of my blocks comes in black color. How can i change that to a different color???
Solved by CoreyDaun. Go to Solution.
Change the color of the Category under Object Styles. If you're within the Family Editor, setting a different color to one of the primary Categories will not override what's already in the project, You can create Subcategories and then when the family is loaded into the project, the new Subcategory will be recognized and assigned the appropriate color.
