Revit MEP
Revit MEP
Active Member
0 Kudos
Post 21 of 37
Re: FABmep for Revit MEP available on Autodesk Labs
09-05-2012 03:47 PM in reply to: scott.sheppard
What do you mean by the extensions. Is this helping you get from FAB MEP to REVIT MEP? That is our current task.
Active Member
0 Kudos
Post 22 of 37
09-05-2012 04:04 PM in reply to: NelsonStark
Where did you get the dll files? We are having this same issue.
Board Manager
26 Kudos
Post 23 of 37
09-06-2012 09:25 AM in reply to: csheesley
Peter Jackson shared some information:
Revit MEP For Engineering 2013 Conversion to Fabrication FABmep 2013
Its Fab Autodesk Fabrication Blog
Extending Autodesk Revit models to Autodesk Fabrication
  • Please see attached taken from the Fabrication Blog. Below is the video link illustrating the process.
Autodesk Fabrication FABmep 2013: Export and Import to Autodesk Revit
Fabrication FABmep 2013 Conversion to Revit MEP For Engineering 2013
Do you need to import Fabrication FABmep models back into Revit MEP?
Taking Fabrication FABmep models back into Revit 2013
http://autodesk.typepad.com/fabrication/2012/08/taking-fabrication-fabmep-models-into-revit.html
Scott Sheppard
Program Manager
Autodesk Labs
Member
0 Kudos
Post 24 of 37
Re: FABmep Import for Revit MEP available on Autodesk Labs
01-14-2013 05:26 PM in reply to: scott.sheppard
I wish you could map things other than dimensions. More specifically item numbers to item mark.
Board Manager
26 Kudos
Post 25 of 37
03-19-2013 03:12 PM in reply to: lhuynh
Thank you for the suggestion. THis is what we need to hear in the technology preview stage.
Scott Sheppard
Program Manager
Autodesk Labs
Board Manager
26 Kudos
Post 26 of 37
04-01-2013 10:01 AM in reply to: scott.sheppard
I have not yet received a new installer from the team although I believe their plan is to continue to collected feedback via an extended technology preview.
Scott Sheppard
Program Manager
Autodesk Labs
Board Manager
26 Kudos
Post 27 of 37
04-09-2013 07:20 AM in reply to: scott.sheppard
I posted a new build on the Autodesk Labs site this morning. This build extends the technology preview for Revit MEP 2013 users to March 31, 2014.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
1 Kudo
Post 28 of 37
04-09-2013 10:54 AM in reply to: csheesley
I have removed old install and try to re-install the new one but just getteing a notice that “The Component has expired and cannot be loaded” what else do I need to do?
Active Contributor
27 Kudos
Post 29 of 37
04-09-2013 11:02 AM in reply to: NelsonStark
Same thing here.Just e-mail Darren before I posted about issue
Bob Parrell
Member
0 Kudos
Post 30 of 37
04-11-2013 12:56 AM in reply to: bparrell
I've contacted the developer directly, he's sent me an email this morning saying that he had updated it and it seems to be working fine now.
Version 3.014.186.0
