Revit MEP
Board Manager
scott.sheppard
Message 11 of 37 (1,602 Views)
Re: FABmep for Revit MEP available on Autodesk Labs
07-09-2012 08:07 AM in reply to: BrianWelch3883
@BrianWelch
I gathered some information from Steve and wrote a blog posting for you.
http://labs.blogs.com/its_alive_in_the_lab/2012/07/fabmep-import-for-revit-mep-now-available-on-auto...
Scott Sheppard
Program Manager
Autodesk Labs
bparrell
Message 12 of 37 (1,597 Views)
Re: FABmep Import for Revit MEP available on Autodesk Labs
07-09-2012 09:17 AM in reply to: bparrell
Figured it out.For those that are interested.They have change the ext on the mapping file.Change from .Bix to .Map and all will be good.
Board Manager
scott.sheppard
Message 13 of 37 (1,583 Views)
07-10-2012 11:10 AM in reply to: bparrell
Based on the inquiries in this forum, I sketched out the workflow.
http://labs.blogs.com/its_alive_in_the_lab/2012/07/fabmep-import-for-revit-mep-a-picture-is-worth-10...
Thanks for providing the impetus.
Scott Sheppard
Program Manager
Autodesk Labs
Active Member
NelsonStark
Message 14 of 37 (1,578 Views)
07-12-2012 09:56 AM in reply to: BrianWelch3883
"exportrun" is the command without the quotes. or "erun" or use icon in FABmep if not there right click in FABmep screen go to tools then click DATA Exchange this will bring the icon up
New Member
ERez1185
Message 15 of 37 (1,567 Views)
07-12-2012 11:07 AM in reply to: NelsonStark
I am running 2.41.157, i did click on data exchange and do not see the icon, i have importrun but no exportrun.
Any suggestions
Active Member
NelsonStark
Message 16 of 37 (1,554 Views)
07-12-2012 11:28 AM in reply to: scott.sheppard
That is the same thing I am running. Now do you have the import icon? Also do you have Fabrication FABmep & Revit installed and if so is the addin's showing up to import and export from Revit? This might be an install problem. Did you download the Autodesk Lab add-on?
New Member
ERez1185
Message 17 of 37 (1,548 Views)
07-12-2012 11:56 AM in reply to: NelsonStark
In FAB i have the import icon but not the export icon.
I downloaded the FABtoRME.zip Revit add-in from Autodesk labs, i installed it and have the FAB to RME add-in.
I have not yet installed Revit convert 2013, i have it for Revit 2012 but not Revit 2013, where can i get that?
Active Member
NelsonStark
Message 18 of 37 (1,541 Views)
07-12-2012 12:12 PM in reply to: scott.sheppard
Try this site I think it was a problem I had after using this everything is working. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19399552&linkID=9243099
bparrell
Message 19 of 37 (1,530 Views)
07-13-2012 11:33 AM in reply to: NelsonStark
I was looking for a place to post this,but we are in dire need of a multiline editor when mapping systems(Revit) to fabrication.Should be able to sort all supply and map.Please
New Member
sthompson069
Message 20 of 37 (1,497 Views)
Import CAD MEch Services into FABMep
08-10-2012 07:22 AM in reply to: scott.sheppard
When I go to import services, nothing happens. Any suggestions?
