Revit MEP
Active Member
UmitB
Message 1 of 3 (1,094 Views)
Exporting DWG Section Lines Disappear
1094 Views, 2 Replies
03-13-2013 03:05 AM
I had an issue with my Revit MEP 2013 product. When I want to export my Revit Plans to DWG file. My section lines disappear. I attached two jpg file. First one is Revit Plan view, whic is include a pipe and section, also "Hide at scales coarse than" is true.  I can see in plan. Second one is DWG file I can only see my pipe can not see my section line and head. What am I doing wrong?
Thanks for your help,
Umit B
thombrady
Message 2 of 3 (1,078 Views)
Re: Exporting DWG Section Lines Disappear
03-13-2013 05:38 AM in reply to: UmitB
If you go to print setup there is an option box for "Hide unreferenced view tags". If this is checked it will not show the section view unless it is referenced with a detail. I would check that first.
Active Member
UmitB
Message 3 of 3 (1,075 Views)
03-13-2013 05:54 AM in reply to: thombrady
Thanks... I found it you are right...
