Revit MEP
Distinguished Contributor
mmermel
Message 1 of 5 (448 Views)
Export to DWF: set default to DWF not DWFx
448 Views, 4 Replies
07-13-2010 06:24 AM
Is there a way to set my default DWF format to DWF instead of DWFx?  My plotter does not currently recognize the DWFx as a valid format, probably because of some issue I have not had time to look into.
Mitch
jd
New Member
jd
Message 2 of 5 (310 Views)
Re: Export to DWF: set default to DWF not DWFx
11-07-2011 04:58 AM in reply to: mmermel
Did you find a solution? We have searches for a way to change the default as well.
Jens
Active Contributor
mradamdavis
Message 3 of 5 (252 Views)
01-04-2012 09:44 AM in reply to: jd
when asked to save your DWF/DWFx file, use the drop down to select what type you would like to use.  Hope it helps
mmermel
Message 4 of 5 (245 Views)
01-04-2012 10:37 AM in reply to: mmermel
Sorry, but that does not help.  I already know about that.  The problem is that no matter how much you educate people about the setting they must use, they forget about it.  That means that if I never want anyone to accidentally plot to a DWFx, I need a way to set DWF as a default.
M
CADastrophe
Message 5 of 5 (240 Views)
01-04-2012 11:09 AM in reply to: mmermel
We have that issue too, with Worksets and DWFs. My solution was to make each user wear a reminder WWJD bracelet. (We Want Just .DWFs!). But there may be converters out there that might be faster than re-plotting.
