Revit MEP Forum
Export to DWF: set default to DWF not DWFx
4 REPLIES 4
mmermel
662 Views, 4 Replies
Is there a way to set my default DWF format to DWF instead of DWFx?  My plotter does not currently recognize the DWFx as a valid format, probably because of some issue I have not had time to look into.
Mitch
4 REPLIES 4
jd
in reply to: mmermel
Did you find a solution? We have searches for a way to change the default as well.
Jens
mradamdavis
in reply to: jd
when asked to save your DWF/DWFx file, use the drop down to select what type you would like to use.  Hope it helps
mmermel
Sorry, but that does not help.  I already know about that.  The problem is that no matter how much you educate people about the setting they must use, they forget about it.  That means that if I never want anyone to accidentally plot to a DWFx, I need a way to set DWF as a default.
M
CoreyDaun
We have that issue too, with Worksets and DWFs. My solution was to make each user wear a reminder WWJD bracelet. (We Want Just .DWFs!). But there may be converters out there that might be faster than re-plotting.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
