I have created an export to dwg setup in one project. I would like to be able to use that export setup in another project. I have searched the discussion groups, and apparently you can create a txt file of your export setup. I've tried, searched, and can't figure that one out. Any help is appreciated. Thank you in advance for any assistance.
Jarrad27
Solved by CoreyDaun. Go to Solution.
I don't see a way to export these options to a .txt file. You can use 'Transfer Project Standards' from the Manage tab to import the settings into another Project. Make sure you have both Projects open* and have the Project that you want to import the settings into the active Project . In the dialog following Transfer Project Standards, ensure that the "Copy From:" at the top displays the correct Project. Then, simple click "Check None" and then find "DWG/DXF Export Setup Settings" from the list and check the box.
*I transferred my export settings to a blank project and saved it. That way, I don't have to open another entire Project from which to copy it, just this specific blank one.
