We're having issues with exporting Revit floorplans to dwg. When opening in AutoCAD some, apparantly random, fittings and accessory are flying around in the drawing. (see attached) The closest we got so far is that it might have something to do with the pipe/duct connected to the fitting. And especially when the pipe/duct on one side has a (really small) slope and on the other side no slope. But still, in some cases this doesn't results in flying fittings. We tried the common stuff as exporting to different versions/extensions. Pinning/hiding elements. With/without scopebox. Etc. No luck so far.
Anyone experienced a similar issue? Thanks.
I've heard of this issue being reported at least a couple of times here, but I don't recall ever hearing about a solution. I would suggest performing some searches on Google or opening a Support Case through the Autodesk Subscription Center on their main website.
