Does anyone know how to export offset properties or for pipes to .dwf? It would be great if it was possible to read offset properties on a pipe from an exported dwf-file.
The only exported pipe property that has anything to do with the z coordinate that I could find, is the invert elevation property which is based on the bottom part of a the pipe.
-Christian
Hello, welcome to the Discussion Groups!
Unfortunately, I believe that Invert Elevation is the closest you can get to extracting that information to a DWF file format. The only other way I can see at the moment would be to create a Project Parameter and then manually enter the Pipe Offset into that Parameter, but that would not serve to be a very good solution.
Hi Christian,
Unfortunately it is currently not possible to have the offset value of pipes in the DWF file. This will require a program modification.
I would recommend that you use the product feedback page to enter your request to the product designers:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Best regards,
