There are two ways to do it, the easiest being - just creating a CALL OUT View, where you rotated it on plan will straighten it out in the view.
Second is, if you are always rotating the same direction, set the new direction to project north, and set your view properties for the view to Project North, and it should rotate out the difference.( I will warn you, every time we have done it, it cause some type of issue. )
