I have a problem with autocad export. In revit mep when i export to cad, some duct fittings or accessories exported out of plan. I figured out that only multiple blocks which have same block name exported out of plan. Is there any way to fix that? And i didnt understand that exported block names coming like 06_Dirsek - 0_75 -60-3374923-_0_70; "3374923" this number changes block names for family. But where it is coming from? Not id or mark value.
Thanks for your helps.
i there is so much people which got the same problem. Autodesk should fix this or give a way to handle this.
http://forums.autodesk.com/t5/revit-mep/problems-in-exporting-revit-model-to-autocad/td-p/2531470
Good thing you came along seven years later to state the same thing. Nothing new to add?
