I am trying to export a sheet in revit with 3D view on it to CAD. The visual style of the 3D is shaded. Is it possible to preserve this view style when I export it to CAD?
Thanks in advance!
Solved by CoreyDaun. Go to Solution.
When you export a Sheet View, all of the associated Views are "flattened" and become two-dimensional. In order to maintain the 3D aspect of these Views, export the 3D Views separately and then xref/insert them into the exported sheet's dwg file. You'll have to recreate the 'shaded' appearance in the AutoCAD files.
