i gathered all templates.. Electrical, Mechanic, Pipe. ..
but it seems doesn't create power circuit properly.
it result dash line when i connected between lightings, panel and switch.
but when i chenck by using "check circuit", it apear to be " circuit is not assigned to a panel "
and even edit wiring mode is not activated.
please help me
thankyou . .
Solved by SteveKStafford. Go to Solution.
Creating circuits is a child to parent relationship that repeats several times for a complete circuit. For example a duplex receptacle (child) connects to a panel (parent). The panel (child) connects to another panel (parent). The panel (child) connects to a transformer (parent). A transformer (child) connects to another panel (parent).
When you create a circuit you are working from child to parent, never parent to child. This means if you select a panel and click the Power button, to create a power circuit, Revit expects you to select the source of the power for this panel. It is a common misconception that we can start at a panel and assign receptacles, lighting or other devices to it. We can't. Revit is always looking UP from the child up to the parent electrical relationship.
When you use Check Circuits Revit is only looking for components that have not been assigned to a circuit yet. If a duplex is reporting as unconnected then it has not been associated with a panel yet. Receptacles cannot be assigned to a panel until the panel as been assigned a Distribution System.
Order of basic operations:
Yes the electrical requirements of panels and transformers can be changed. They are assigned at the connector in each family. Some are assigned to instance parameters which makes it easier to change once they are in the project but many more are type parameters which require a new type to change them.
A project must also have Voltage Definitions and Distribution Systems defined that provide the electrical conditions you intend to use. If these are not ready then you can't assign panels and transformers to a distribution system which in turn prevents you from creating circuits, electrical relationships between elements.
Well my first attempt to reply failed when the forum wouldn't permit me to attach a sample file. I've made a sample file AVAILABLE HERE instead (it is a Revit 2015 file). The file (images attached show what is in the file) just shows basic electrical relationships between duplex outlets and lighting fixtures, their panels, the panels and transformers and finally the transformers to a main distribution panel. The file is based on the stock imperial electrical template that Autodesk provides. Either the imperial or electrical templates are a reasonable place to start getting acquainted because the components that are loaded already should work together as long as you assign distribution systems to each component correctly.
The electrical relationships begin at the devices and work "up" toward their source of electricity.
You can customize the voltage setting for families but it varies from family to family. In some cases they are assigned a voltage within the family (via its connector) and you must edit the family to change it. The MEPVoltDist02 image attached shows a panel family that Voltage is assigned and only editable within the family. Other families have associated the voltage with a parameter that will allow you to change it from within its properties while using it in the project. If you select a family and the voltage parameter isn't available in the Properties Palette or Type Properties dialog then it can only be changed in the family itself.
If a family is assigned 480 VAC then it cannot be associated with a different Distribution System without revising its voltage first. Therefore our electrical component library must be configured to support the kinds of work we usually do.
