I'm making a custom annotation tag for grills. I want the tag to include the flow parameter of the diffuser that it references; however, having the units is unnessesary and would make the tag larger than it needs to be. Is there a way to use the flow parameter and exclude the units of the flow (i.e L/s) when it displays?
Solved by bvm76. Go to Solution.
Edit the tag family (see attached).
Once done, reload the tag family. This will change all tags of this type. If you dont want to change all, then you need to create another type before editing.
