I get the Operation could not be completed eror jut about every 5-10 minutes when working in MEP13. The full error is "This operation could not be completed. Please try again. If the problem persists, save any changes to models from the Revit server locally and contact your administrator."
I can't seem to do anything with out getting that meassage. I can't save after I make an inital central file and it doesn't look like I make a central file at all because the save and sync are greyed out.
Did you export the errors and warning message? It will list the conflict. It may have something to do with the setup of your model.
Are you Creating a "Local" File AFTER creating the Central?.....Sounds like you're still working in the Central file.
Mike
I get this after we have created the central and have made a new local copy. It doesn't seem to be project spacific either.
