Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
ERROR: "Elements need to be disconnected"
1 REPLY 1
chris.lorenz
1864 Views, 1 Reply
Is there a way to disable this message from popping up every time I demolish something?  If I'm doing a job that is a major renovation, It becomes incredibly tiresome to have to go through that for everything I want to demolish.
1 REPLY 1
CoreyDaun
in reply to: chris.lorenz
Hello, and welcome to the Discussion Groups!
I don't think there's a way to bypass that. I agree, it's quite annoying that you cannot even hit "D" for the "Disconnect" option in the warning message; you have to click the button every time. Just try to change as many elements at once as you can. ~shrugs~
Perhaps you can use this below, which is frequently provided by Autodesk Support personnel 'round here.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
