Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Error in saving Lookup Table
3 REPLIES 3
bvm76
290 Views, 3 Replies
I'm not quite sure why I get this error when I am saving a lookup table (please see attached).
What I did was duplicate the existing lookup table, rename then save.
Any help will be much appreciated.
Please mark Accept as Solution if your question is answered!
Thank You.
3 REPLIES 3
CoreyDaun
in reply to: bvm76
Sorry for the late reply!
Is this still an issue for you? Did it produce errors if you clicked "Yes" and then used it in a Family?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
bvm76
in reply to: CoreyDaun
Thanks for getting back to this Corey.
The table works fine. I just want to get rid of this error if possible.
Thank You.
CoreyDaun
in reply to: bvm76
That is a warning rather than an error, because you are working in a file format that is foreign to Excel. As far as I know, there is no way to escape that error without creating a Visual Basics script that saves it (in lieu of manually saving it), which would skip the prompt. It wouldn't be worth the effort, though.
