I have in fact recently created several electrical families and found that if you made the symol in a detail components file, you must then create your text in an annotation file then load it into the other. When everything is done and you have it loaded into your project, you will find that your text moves and rotates with your drawing. If you feel the need to chge it, your going to have to go and edit family. Hopefully this helps.
