Revit MEP
Active Contributor
DMaurer-Veca
Message 1 of 6 (414 Views)
Electrical conduit - bends show but not pipe
414 Views, 5 Replies
01-24-2013 08:28 AM
In the power floor plan drawing I have a workset for the slab with branch conduit drawn as 'Conduit without fittings RCN schedule 40'. The straight sections of pipe are not showing but the bends do show. I have check VG settings for visiblitly settins of the workset as well as filters and view range. All things being equal between the conduit and the bends connecting the straight pieces, why are only the bends showing? The problem does not repeat on other plan views. Any help is appreciated.
Diane M
CADastrophe
Message 2 of 6 (411 Views)
Re: Electrical conduit - bends show but not pipe
01-24-2013 08:44 AM in reply to: DMaurer-Veca
Is there a Plan Region involved here? That looks like the typical mess that results from those and certain MEP elements.
If not, does setting the View to Wireframe cause the Conduit to appear?
Active Contributor
DMaurer-Veca
Message 3 of 6 (406 Views)
01-24-2013 09:12 AM in reply to: CADastrophe
No plan reagion and changing to wire frame did not change anything.
Diane M
CADastrophe
Message 4 of 6 (405 Views)
01-24-2013 09:18 AM in reply to: DMaurer-Veca
Before I start randomly digging and poking around for the cause, can you apply a View Template from one of the Views that is displaying correctly?
Active Contributor
DMaurer-Veca
Message 5 of 6 (393 Views)
01-24-2013 01:21 PM in reply to: CADastrophe
Sorry for the delay, we decided to run an augidt, which is finished now, but now change in the conduit visibility issue. The conduit does show up in a different floor plan view, although the filters and workset settings are the same. We discovered if we change the conduit from PVC Schedule 40 to PVC Schedule 80 it reapears.
Diane M
Active Contributor
DMaurer-Veca
Message 6 of 6 (389 Views)
01-24-2013 01:31 PM in reply to: DMaurer-Veca
I just solved the problem. The filter I used to turn off the Telecom systems conduit was set for PVC Schedule 40. I modified filter to add the workset Telecom Distribution, and that solved the problem.
Diane M
