Hello - I have a client that contacted me about this issue...
When they sync with the central model - the electrical circuits are disconnecting from lights and disappear from the panel schedule...
Any one having this issue - or any ideas why it would happen?
Thanks!
LD
Solved by troystockwell. Go to Solution.
I've seen this asked here a few times, but never have I seen an answer. However, I did search AUGI and found an enigmatic answer in this thread:
Revit Electrical circuits disconnecting from parent when synchronizing
I wouldn't be able to help on this issue without being able to see it for myself.
This is a big project and it goes out next week so any help you can provide I would really appreciate it.
I'd be happy to do what I can.
4 people, 300,000 sq ft building, Lights only. No copy monitoring anymore, Arch placed light, then we copy monitored. Those have been taken out and eliminated. ignoring all categories for copy monitor now. except levels and grids. All worksets are open. Revit MEP 13, everyone makes new locals daily. random lights, never in a pattern. no special about the lights from one another either.
Without being able to tinker with it myself, I won't be able to do anything more than toss random suggestions out there. *shrugs*
Have you taken a peek at the link I provided to the AUGI thread in my first reply? If not, take a peek and see if that relates to your situation at all.
As another uneducated suggestion, maybe try disconnecting the lighting circuits from the panel yourself. Save and synch, and then connect the circuits again, save and synch. Is this happening in particular with the most recent panels that were added, or the oldest?
That is interesting Troy -Glad you were able to figure it out - I was completely lost...
LD
We are having this issue also, but I don't quite understand your solution.
What do you mean by "clipping" the circuit?
Are you talking about Batch Copy options?
Thanks so much for your help!
