We are currently using block views that are not dependent duplicates so that our cropping does not have to be rectilinear, but this will not allow me to circuit between the blocks. Since the views are not dependent I have to circuit in the block views. Is there any way to get the circuiting to show on the block views when inserted on the composite view, or any other solution? Thanks.
