Revit MEP
Distinguished Contributor
auto99
Message 1 of 4 (198 Views)
Electrical annotation transparency
198 Views, 3 Replies
11-24-2012 09:57 AM
You can see my disconnect switches creates a line gap on the HVAC equipment they attaches to.  Is there something I can change to make it transparent?
Or can I do wireframe selectively?  Just the HVAC on wireframe view?
*Expert Elite*
CADastrophe
Message 2 of 4 (158 Views)
Re: Electrical annotation transparency
11-26-2012 05:35 AM in reply to: auto99
The source of this behavior is under Mechanical Settings » Hidden Line. You can either disable "Draw MEP Hidden Lines" or set the gap sizes to 0.
The above is a Project-wide effect, though. You can eliminate this per View by setting the Visual Style to Wireframe, but you cannot assign a Visual Style to a specific Category. You could also change the View's Discipline to Coordination to prevent Revit from creating these gaps.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
auto99
Message 3 of 4 (139 Views)
11-26-2012 01:56 PM in reply to: CADastrophe
Thank you.  I guess I have to live with this limitation.
*Expert Elite*
abulla
Message 4 of 4 (117 Views)
11-27-2012 07:52 AM in reply to: auto99
In this particular view, you could turn your Mechanical Equipment to transparent, that may clear up some of the issues.
Need installation help?
