Revit MEP Forum
Electric Panel Voltage - 120, 240
2 REPLIES 2
will
386 Views, 2 Replies
Hello -
is it possible to add 240 V components to an Panel associated with a 120 V Power Distribution / Voltage setting?
So far, I get errors when I try this.
-Will
2 REPLIES 2
CoreyDaun
in reply to: will
Hi Will,
Please elaborate on this with a little more:
- What is your Distribution System? How many Phases?
- How many Poles/Phases is the 240V component?
will
in reply to: CoreyDaun
Hello Corey
I found the issue.
My Distribution System was set to 2 Wire, which was preventing me from setting an L-L voltage.
Thanks for the response!
-Will
