dear all
everytime i make the duct smaller on 1 side, the recctangle redcucer appears automatically
all i wanted it "eccentric" reducer,
now i read online about using "justify" or "align" but none of them did work with me, can anyone help me step by step
how to create / do it ?
that would be really really really great
thanks 🙂
Solved by abulla. Go to Solution.
happen to have this video on youtube maybe? since flashplayer doesn't exist anymore.
Hi Abulla, are you able to provide this video on a different platform? As mentioned above, flash is no longer supported on browsers 😞
Hope this attachment helps.
Transition family has to be of the eccentric type in your routing preferences, it won't work with a concentric family.
Thank you sir, much appreciated! I actually figured it out in the end using the justify function, but your method is a lot easier... in fact, I think that was what I was trying in the first instance but with no success oddly. I'm modelling from point cloud and often the real world geometry just throws up issues with Revit!
