Revit MEP Forum
Duplicate columns in equipment schedules
5 REPLIES 5
Mehdi.Kardehi
779 Views, 5 Replies
Hi All,
I made two mechanical equipment...one is a fancoil unit and the other one is a fan..
I had shared parameters in both families to help populate my schedules with
When I am going to add fields to my schedules there are two of each item...for example there are two parameters called Equipment Tag...two of them called Weight Etc....
Can some one please tell me what I have done wrong? Schedule attached
M
5 REPLIES 5
I think you add a different attchment. Can you please check.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
Sorry..wrong attachment...please see attached the correct one
Revit file also attached
I found the source of the issue...I am using two seperate text files for shared parameters of families...one for fan coils and the other one for fans....THey both have a parameter called equipment tag..I use that to modify the tagging in my drawings...There are also other parameters in common like equipment category...weight...height...depth...etc...
Any thoughts how to get around this issue...
All I am trying is to avoid having a big list of shared parameters in only one file...This way I can have 10 files with 20 items each instead of having only one shared parameters file with 100 items in it!
I think I just found the solution...
They were exactly same parametrs but were grouped in different groups in the shared parameter files...
To make it work I chenged the grouping of the shared parameters in a way that they all belong to one group in all the small shared parameter files....in this way I can make sure that my schedules look fine
