Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Ductwork justification
1 REPLY 1
IanMatthews
179 Views, 1 Reply
If I'm drawing a ductwork run in plan I can set the justification to the left, for example, and the run will be flat sided on the left as it changes size.
In 2008, the justification option wasn't available when you were in section 'cos you couldn't draw in section. But apparently it still isn't in 2009. It seems that I have to set the justification in plan, then switch to the section and keep swapping between the two as I change it.
Is there another way of doing this or should it really go onto the wish list?
1 REPLY 1
Hey Ian,
I just pinged our lead developer on our layout functionality to confirm the status of this functionality. I'll let you know what he says.
Cheers,
Kyle B
Revit MEP Product Manager
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
