I Revit users,
I have created a tag with two parameters. Diameter and flow. I just want to know what I have to do to control the flow in a duct in order to the flow appears in the tag that I made.
Best regards
Your Duct(s) should be reporting an Air Flow if connected to one or more Air Terminals. The specific Air Flow is determined by the Air Terminals, and if your Duct Tag is reading 0 for Air Flow, then it is likely not properly connected to the Air Terminal(s). See image below.
If your Duct Tag is reporting "Not Computed", then the calculation have been disabled and can be re-enabled by going to Project Browser » Families » Duct Systems » Duct System and going to the Type Properties of that Duct System. There, you will find the calculation settings.
