Hi everyone,
I have ben using Revit MEP 2015 several weeks especially on ductwork but i stuck at one point. Whenever come across the duct junction i replace and give dimensions of wye fittings with my hand due to volume that duct required. I think it should be a wye family in the program library but i couldn't find it. could anyone help me please thanks!
Revit 2015 is your first software? or you have experience in using older version of this software? If you have been moved from 2012 to 2015 you should note that some lookup table changes are made in between versions.
I hope this is something you need to check with your lookup table.
