Revit MEP
Active Member
dworakma
Message 1 of 5 (827 Views)
Duct Sizing
827 Views, 4 Replies
01-17-2012 09:51 AM
We're still not using the duct sizing feature in Revit and I would love to start.
Curious who is using it?
The problem I've repeatedly ran into is that airflows are not transferred back into my duct main from the terminal device.  I can assign airflow to a terminal device, such as a supply air diffuser (using a "preset" flow configuration parameter).  And that airflow will be visible at the branch duct connected to the diffuser, but once connected to a main my airflow at the main shows 0 CFM.  I believe my system is well defined starting with equipment and terminal devices, as the equipment shows the correct total airflow for the system in my system browser.  Any thoughts as to what I'm doing wrong?
Thanks in advance.
Matt
Distinguished Mentor
Jrobker
Message 2 of 5 (815 Views)
Re: Duct Sizing
01-17-2012 02:59 PM in reply to: dworakma
See this diagram,
"It's hardware that makes a machine fast. It's software that makes a fast machine slow."
Active Member
dworakma
Message 3 of 5 (806 Views)
Re: Duct Sizing
01-17-2012 06:55 PM in reply to: Jrobker
J,
Thanks for posting the graphic, it's very helpful.  I'll double check some of my settings when I get to the office in the morning.
Could I assume your using the duct sizing feature?
Thanks again.
Jrobker
Message 4 of 5 (792 Views)
Re: Duct Sizing
01-18-2012 08:27 AM in reply to: dworakma
No. We are not. There is no static pressure drop or CFM loss after a duct tap. Doesn't quite work. Plus issues with critical path. Doesn't work right and never has. Hopefully release 5 (2013) will get it right, since marketing claims it does.
Active Member
dworakma
Message 5 of 5 (788 Views)
Re: Duct Sizing
01-18-2012 08:34 AM in reply to: dworakma
Dang that's a bummer, you got my hopes up with that fancy drawing.  Thanks for your input.
I'll keep my fingers crossed that it shows up in a next release and actually works!
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
