Is there any way to customise the rise / drop symbol for ducts?
In Hong Kong, there used to be a government standard for rise/drop symbol. It can be an obstacle to implement Revit if the symbol cannot be exactly the same so that Revit produced drawings get rejected. (though the Revit symbol is close to, see attachment)
Unfortunately, as of Revit 2014, the symbols cannot be customized. Below is a link that is frequently provided by Autodesk Support personnel that visit these forums. Use this to provide them with feedback about this issue.
Autodesk Product Support"The following link is setup for you to submit feature requests, or feedback, directly to our Development group:"
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Hi Corey
How to get the symbol shown in the attached file?
What I have is only two symbols shown in the secong picture
Unfortunately, these symbols are not customizable. You are limited to the choices offered under each Duct System's Type Properties. If you need to be able to customize these symbols, use the following link, which is frequently suggested by Autodesk Support personnel here.
