Revit MEP Forum
Duct Rise/Drop "Ying Yang" issue
2 REPLIES 2
asommer
1879 Views, 2 Replies
Revit MEP 2010... I set up the Rise/Drop symbol for duct, and it works fine in Plan view.  I cut a section, the section clearly intersects the ducts.  It will only show the Rise/Drop infill symbol in WIREFRAME.  If I change to HIDDEN LINE, they won't show.  What gives?
2 REPLIES 2
CoreyDaun
in reply to: asommer
I see what you mean - the solid fill vanishes, but the rest of the symbol seems to be correct. It appears to be an issue with RMEP 2010 that was addressed and corrected in RMEP 2011. I think you could draw a filled region over the symbol if you were desperate...
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
asommer
in reply to: CoreyDaun
Ya, that's what I've been doing.
