hi
What is the purpose of Duct Rise / Drop Annotation Size?
Please do on the image.
Solved by L.Maas. Go to Solution.
It is the same as with the pipe settings. It determines the size of the symbols for rising and dropping pipes (or ducts). Note that it is a project wide setting
Underneath screenshot, two projects. One with Pipe Rise/Drop Annotation Size of 3 mm. In the second project increased to 10 mm.
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for your answer
But my problem is on Duct
This change does not display Duct
You are correct. I assumed it was the same for pipe as duct (do not much duct myself). Apparently duct does not have single line drop/rise symbols (anymore?).
Duct will show the rise symbol based on the size of the ducting. Then it appears indeed that the "Duct Rise/Drop Annotation Size" has no function (anymore). So historical leftover?
Louis
Thank YOU
