Hey All,
Having a draw order issue with ductwork hatch that is being applied by a filter.
Typical filter. Lining thickness = value......apply certain hatch pattern (ducts, fittings, accessories)
As revit does, all looks fine while modelling. Then you print and the issue arises.
The duct which is running away (showing the drop symbol) is having the hatch pattern applied and overlaying, draw order is all messed up.
However if I turn off hidden lines then it prints fine.
Any ideas? cant really turn hidden lines off
Cheers,
Josh
