Revit MEP Forum
Duct fitting question
6 REPLIES 6
Paul-s
766 Views, 6 Replies
6 REPLIES 6
ep_cwclose
in reply to: Paul-s
Depends if you're interested in the Revit systems aspect, but to model that you could use an in-place sweep family to create the top elbow (setting the category to duct fittings and adding a connector to the end) and another in-place family for the straight fitting with a normal transition duct fitting at the end of it.  (See Revit screenshot)Capture.JPG
Sandleaz
in reply to: Paul-s
How would you draw this? What fittings do you use?
I start with big purple R --> new -> family and categorize it as a duct fitting (multi-port).  Then I model it.  I never use in-place families.
Paul-s
in reply to: Paul-s
Ahh..So thats how you do it. I was going crazy looking for duct fittings. Thank you guys!
Cwclose. if the file is not too big. can you please attached that model so that I can study it.
ep_cwclose
in reply to: Paul-s
The file is too big for the Autodesk discussion groups.  I can send you the file via email or ftp.  That said, I agree with Sandleaz, if you can use a regular duct fitting family vs. in-place--do so.  However, if you're only needing the geometry (as is the objective of many MEP design and construction firms) and you aren't using the air flow data then modeling in-place might be quicker for unique circumstaces.  HTH
kyuen
in reply to: Paul-s
I am looking for this fitting also, can you send email to me also.
thank you.
dbrown-uskh
in reply to: Paul-s
please send the duct file also  thanks
