Revit MEP Forum
Duct Fitting Issue
9 REPLIES 9
Message 1 of 10
677 Views, 9 Replies
Duct Fitting Issue
I am trying to make a custom tee and I have problem that I can't solve.
When I make a tee from an elbow it works fine (Duct Fitting_1.jpg and Duct Fitting_2.jpg) but when I try to make a tee from the middle of the duct I get an error and I don't know what to do (Duct Fitting_3.jpg an Duct Fitting_4.jpg).
Please help! I have attached pictures and revit family of the duct fitting.
9 REPLIES 9
Message 2 of 10
I think "preferred junction type" in the routing preference is set to tap instead of tee as you want.
You can change it as follows- go to edit type of duct-> routing preference-edit->preferred junction type-> "TEE"
Message 3 of 10
No, it is set to tee. :S Did you try to use my duct fitting?!
Anyone else any suggestions?!
Message 4 of 10
CoreyDaun
~picks up loupe and inspects Family~
To begin, I'm of the electrical discipline so my expertise it not quite up to par in this category. Anyway, I was comparing your Family to the default OOTB Tee and I did not see what could be causing that error.
Also, I had loaded your Family into my test Project and create a separate Duct Type for it. I was using the stardard Rectangular Duct and remove the "Tee" Preference (set it to "none") and for whatever reason, Revit uses your Family correctly. I'll keep investigating this if I get some more time to do so.
Smiley Frustrated
BTW - Welcome to the Discussion Groups!
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 5 of 10
Go to the edit family of the duct fitting in the Properties pallet change the the "Part type" to TEE (If its already TEE change it to something else, load it, then again change it to TEE and then load it again) then in the routing preference set it to tee if not already done.
Message 6 of 10
in reply to: CoreyDaun
Yeah, this thing really works. Did you find out why is that so?!
Message 7 of 10
I don't get it. I am trying to do that and it doesn't work. Can you print screen and make a quick tutorial from it?!
Message 8 of 10
CoreyDaun
I have looked into this further, I think that this may be caused by the orientation of the geometry in the Family Editor AND/OR the placement order of the Duct Connectors (compared to the OOTB Duct Fitting Family). Originally, I started a new Duct Tee Family and built it haphazardly and encountered the exact same errors you did. However, I went back this morning and create another one a bit more carefully, matching the orientation and the placement order (below) of the Connectors, and my Fitting worked. In lieu of dissecting this Family to find the cause, see if you can recreate it based off of the way the OOTB Duct Tee is designed.
                     linked
DC #1 (Pri) <---------> DC #2
                  DC #3
Message 9 of 10
sorry I can't, I am busy now-a-days try the steps one more time
Message 10 of 10
bwright
I looked at your fitting I believe it's one of two things and not easy to correct or at least would take time.
1. your fitting needs to be rotated 90 deg counter clockwise. Also make sure primary connected is at 9 o'clock position as primary connectors should be placed on the X plane. Obviously to correct this will require a rebuild so save as on this one and try another.
if this does not work try
2. all tees are built with sweeps and not one extrusion. not sure if this could be the issue, I have personally never built a tee without using sweeps, so you might want to look into that.
As for the changing of the part type this did not work. If it worked for the other posted encourage him to post the fixed tee.
good luck.
Bill Wright
