Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
Did you mean:Ā
Duct Creation Problem In offset Revit 2013
3 REPLIES 3
SinghManish
1287 Views, 3 Replies
Dear,
I have a problem with revit Duct drawing through programme in C#.
Explanation: I draw a duct 24''*12'' with offset 0.0 to 50'' then i change offset 0.0 to 9.0 and then draw to 50'' and again i change offset to 0.0 . After that Drawn duct shows the size 24''*12'' but appearnce is not proper you can see in image. Please help me  if anyone has solution.
Manish Singh
Tags (1)
3 REPLIES 3
nitinjambhale
in reply to: SinghManish
i think the problem is of Width, depth setting. Please check at once.
DMallikarjuna
Hi All,
The question which asked my Manish, is good one, i am wondering for this answer.
Please reply any one, if you people already done.
Thank You,
Mallikarjuna
SinghManish
in reply to: nitinjambhale
I set Hight and width correct. But looks same  as image above.
Manish Singh
