Revit MEP
Revit MEP
5 Kudos
Post 1 of 4
Duct Creation Problem In offset Revit 2013
999 Views, 3 Replies
01-03-2013 01:35 AM
Dear,
I have a problem with revit Duct drawing through programme in C#.
Explanation: I draw a duct 24''*12'' with offset 0.0 to 50'' then i change offset 0.0 to 9.0 and then draw to 50'' and again i change offset to 0.0 . After that Drawn duct shows the size 24''*12'' but appearnce is not proper you can see in image. Please help me  if anyone has solution.
Active Contributor
1 Kudo
Post 2 of 4
Re: Duct Creation Problem In offset Revit 2013
01-03-2013 01:47 AM in reply to: manishsingh12jan
i think the problem is of Width, depth setting. Please check at once.
Active Member
0 Kudos
Post 3 of 4
Hi All,
The question which asked my Manish, is good one, i am wondering for this answer.
Please reply any one, if you people already done.
Thankyou,
Mallikarjuna
5 Kudos
Post 4 of 4
01-03-2013 01:48 AM in reply to: nitinjambhale
I set Hight and width correct. But looks same  as image above.
