Hi All,
I have made numerous fancoil unit families so far but this is the same time below is happening to me. Can someone help please?
When I select the face and add the supply air connector Revit put is offset from where I want although all the dimensions are set the same. I also figured out that I am not able to move it to it's right position!
Found the issue guys...
instead of using rectangle to make my supply connector I have used lines for this one...
It might have been something wrong with defining the constraints for the lines but as soon as I replaced it with a rectangle the issue is fixed!
