Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct Connector - extension Elbow
1 REPLY 1
mpalan2009
291 Views, 1 Reply
We have set up some mechanical equipmet with ductwork connectors.  When we try to extend the ductwork to connect to other equipment Revit seems to put a 3' straight perpendictular extension in the line of hte connector.  Is there a way to have the connector start with an elbow?
Matthew
1 REPLY 1
CoreyDaun
in reply to: mpalan2009
Not automatically. You will have to create the Duct with the straight segment and elbow, delete the unwanted segment, and then select and drag the elbow by the Connector to manually connect it to the Mechanical Equipment.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
