Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Duct Calculations are incorrect when removing a air terminal from a system
3 REPLIES 3
msoren
308 Views, 3 Replies
I have created duct systems and everything works out well until I needed to remove a diffuser. when I removed the diffuser and associated duct/fittings the CFM for the system did not adjust to the new CFM. when I deleted just the diffuser the same thing occurred. However when I deleted just the fitting the CFM changed. I see nothing the family that would suggest it has a flow value associated with it so once the fitting is removed from the system it should correct itself Right? I'm I doing something wrong or is this another "feature" of Revit?
Tags (1)
3 REPLIES 3
Chris.Aquino
in reply to: msoren
To help the community get a better idea of what is happening, please reply with a small sample file showing the behavior.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
msoren
in reply to: Chris.Aquino
Attached is the issues that I am dealing with the issue seems to lay in the ability to select all and have both of the systems update the CFM.
msoren
Rail Community
