Revit MEP Forum
Duct branch connection results in single line duct
4 REPLIES 4
KevinMurtha
805 Views, 4 Replies
Revit 2013 with latest service pack installed and relativly new to Revit.
when i extend a branch duct to connect to a main duct the reult is the maain duct is shown single line (see attchaeed images). have looked all over for settings and have tried different options for sizes but alweays with the same reults. both ductare aqt the same elevation. can anyone help?
4 REPLIES 4
KevinMurtha
in reply to: KevinMurtha
Any takers? im pretty desparate for a solution
KevinMurtha
Ok.. iv tried the same scenario in a new project and it connects without turning the main duct into a single line so it must be a setting somewhere?
the file i have the problem with was created by another company.
CoreyDaun
Does the duct main change to single line in all Views within that Project? Also, have you tried recreating the main?
KevinMurtha
in reply to: CoreyDaun
found the culprit! it was in `Properties' `Colour Schemes'
the image shows what was set up. when I change the selection on `Ducts' to `none' the problem resolves itself.
Rail Community
