Revit MEP Forum
Dual Voltage In Schedules
17 REPLIES 17
Message 1 of 18
TerribleTim68
1203 Views, 17 Replies
Hey guys,
Have any of you ran into needing to show dual voltage in your schedules? How are you handling it? I have an item I need to show as "120/208", but Revit won't accept the "/", or a dash, or any other non number integer. What are you guys doing for your dual voltage items?
17 REPLIES 17
Message 2 of 18
CoreyDaun
in reply to: TerribleTim68
If you want to "show" (in a Tag or Schedule) dual voltage, you have to do so with a Shared Text Parameter with a formula to compile the text. Can you provide some specifics on your situation; how/where are you intending on showing this dual voltage info? Is an actual Voltage parameter driving the Electrical Connector of your Family?
Message 3 of 18
TerribleTim68
in reply to: CoreyDaun
Yes, as shown in the attached pic in OP, it is an actual electrical voltage parameter. I also need it to stay as an electrical voltage parameter for scheduling purposes. We have a huge list of items, some have electrical data, some have plumbing data, and we filter them to only show the ones with electrical data in one schedule, and then the ones with plumbing data in another schedule. The problem with using a "text" parameter is that it would end up being a different column in the schedule, plus make filtering insane. So you'd end up with almost all items having the electrical voltage in the "VOLTS" column, and then a couple items with that data in a different column. For now we're leaving it blank and inputting "120/208" in the comments column. But that's not ideal. I need to find a better solution. Smiley Sad
Message 4 of 18
Here is a pic of a given schedule showing an item that should read 120/208 in the "VOLTS" column.
Message 5 of 18
CoreyDaun
The quickest, most immediate solution I can offer you (in regard to the Schedule) is to enter a slightly-off value for the Voltage, such as 121V for the instances of dual-voltage. In your Schedule, create a Calculated Value (Text) with the Formula:
= if(Voltage = 121 V, "120/208", if(Voltage = 208 V, "208", "120"))
Hide your actual Voltage Parameter and display this Calculated Value in its place. Note that the above formula must account for every possible Voltage that you use to work properly. A more complete formula would be:
= if(Voltage = 121 V, "120/208", if(Voltage = 208 V, "208", if(Voltage = 278 V, "277/480", if(Voltage = 277 V, "277", if(Voltage = 480 V, "480", "120")))))
Message 6 of 18
TerribleTim68
Thanks for the reply Cory. I've been poking at an if statement to somehow get there. Looks like it will be a little more drawn out so that it covers all possible voltages needed. This may take some effort, but I think you got me pointed the right direction at least.
Message 7 of 18
Loyjoy
now I want to add an automatic volt 121 so I try this :
if(120_208_DualVoltage , Volts , "121 v")
it's not working
Message 8 of 18
in reply to: Loyjoy
it's not working
Why is the Calculated value type Current (unit = A)?  Should it be Electrical Potential (unit = V)?
Message 9 of 18
Loyjoy
in reply to: ToanDN
sorry did not work same message inconsistent units
Message 10 of 18
in reply to: Loyjoy
Can you list the type of parameter for all the parameters listed in the formula?
Message 11 of 18
Loyjoy
in reply to: ToanDN
Message 12 of 18
in reply to: Loyjoy
Sorry.  A snapshot of your schedule is not necessary.  What is the parameter type of:  Volts?
it's not working
Message 13 of 18
Loyjoy
in reply to: ToanDN
Message 14 of 18
Loyjoy
in reply to: ToanDN
and then I use your suggestion - if(Volts = 121 V, "120/208", if(Volts = 208 V, "208", if(Volts = 278 V, "277/480", if(Volts = 277 V, "277", if(Volts = 480 V, "480", "120")))))
now I want to use a Yes / no Paramiter to make it  121 and 278 or 277 tpo make it a dua volt
Message 15 of 18
in reply to: ToanDN
it's not working
The reason it is not working is that Volts is Electrical potential and the Calculated Value is Text.  Text don't understand what the voltage value of Volts means.
Message 16 of 18
in reply to: Loyjoy
The formula above looks correct.  If you want a box to be checked if dual-voltage then try this:
Yes/No parameter: Dual_Voltage
Formula: IF ( OR ( Volts = 121 V, Volts = 277 V), 1<2, 1>2)
Message 17 of 18
TerribleTim68
Okay, so to follow up on this because I actually like this solution -
How do I go about removing the "Volts" column from my schedule? I don't want to have the "Volts" column in the schedule if I'm replacing it with this new "calculated value" column. Because every time I try to remove the "Volts" field from my schedule I get a message saying "You are removing a field used by Calculated Value field(s). You can remove the field by editing the properties of the affected Calculated Value field(s)." What does that mean exactly?
Message 18 of 18
fabiosato
If you use a column in a formula, you can´t remove it, hiding it is the option.
Fábio Sato
