Revit MEP Forum
drainage systems
2 REPLIES 2
jshabry
407 Views, 2 Replies
drainage systems
im new to revit MEP and im doing drainage systems right now... so can any one tel me how to draw a slope pipe and how to connect tht pies to another pipe????? its k doing with autoconnect setting?????
2 REPLIES 2
in reply to: jshabry
The way I do it and maybe others do it different.  I always draw in my main from the farthest fixture with the slope addedin.  Then any branch lines that may need to be added I go from the main with the inherit elevation checked.
WheelerCJ
You can draw your pipe then apply a slop after or you can apply the slope while drawing your pipe.
2014 - Go to Systems, Pipe then on the far right of the Modify | Place Pipe you will see the slope options. You can slope up/down and select the slope value from the drop down box.
For connecting sloped pipes sometimes its best to work in section view.
Have a play and you'll quickly suss it out.
